Configure CP Limit functionality to protect the switch from becoming congested by an excess of data flowing through one or more ports.
- In the Device Physical View tab, select a port.
- In the navigation pane, expand Configuration > Edit > Port.
- Select General.
- Select the CP Limit tab.
- Select AutoRecoverPort.
- Select Apply.
CP Limit Field Descriptions
Use the data in the following table to use the CP Limit tab.
Name |
Description |
AutoRecoverPort |
Activates or disables auto recovery of the port from action taken by CP Limit or link flap features. The default value is disabled. |
